#1 | |
![]() Drives: Yaris Join Date: Dec 2010
Can take a look at the belt and replace the Cabin Filter (maybe I forgot and replaced only the Engine Air Filter earlier). But other than that, all else looks like a st(d)ealer list to me. Wife never knew to ask for Battery Test results, so no go there. Wondering if I should call the dealer and ask. Since battery has not given any problems yet, I don't think it would die just one day. I thought it would start giving problems - multiple cranks needed to start etc. etc. which would be an indication of "not holding charge". Isn't it? |
#2 | |
This is in a cold climate but all my batteries (about 3 of them) have died in the summer months. One of them I actually warned my wife about and luckily sent my jumper cables with her when she went 3 hours up North for work the next morning and sure enough after her meeting her car wouldn't start. The crazy thing is the only reason I knew was by a very and I mean very slight difference in pitch of the noise when I cranked her car to start the day before. Absolutely no issues in cranking over until it died. The list from the dealer is far from the manufacturers recommendations but in all honesty it is not really excessive in terms of wanting to keep your car preventatively maintained and functioning. I tend to not like to over wrench a car needlessly (ie: my oil changes are every 15k km as per oil analysis) but I would do almost everything on that list at one time or another before I got to those miles maybe for the exception of battery and belts if they check out fine. The PCV valve doesn't need to be replaced just remove it an spray it with brake cleaner through both ends and shake it. I do this every oil change and although it is never clogged or even close, it does gum itself up a bit every time I check it. The noise when I shake it is significantly different after I clean it. I would recommend checking brakes once a year and servicing and adjusting them. The rear drum adjuster tend to not work well and I like the hand brake to be firm. If brakes are not lubed ever few years up here they start to seize due to the amount of salt and crap on our roads.
| CP Sent Items | 2+2 | Suggestions - Feedback - Questions | 2 | 07-31-2009 04:06 PM |
| Photo-Scavenger Hunt - THE LIST | Black Yaris | Photo-Video-Media Gallery | 22 | 03-04-2009 08:35 PM |
| Dealer(s) told me they needed to run my credit report even though I'm... | firebird1999us | New YARIS Purchase Forum | 32 | 02-10-2009 10:08 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
| Yarisworld Parts List - Work in progress | vodkalush | General Yaris / Vitz Discussion | 5 | 02-13-2007 06:12 PM |
