Old 01-23-2017, 05:43 PM   #1
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Originally Posted by Motzking1 View Post
So my 2013 Toyota Yaris rear view mirror seems loose. When you're going down the road it's kind of bouncing. I found it annoying enough to try to look at it and see if I can fix it. Upon inspection I found it to be an extremely easy fix. I thought I'd post this see if anybody else is having the same problem. It's literally less than a one minute fix.
1. Pull up on the rear view mirror assembly towards the headliner this will disengage the rear view mirror from the lug on the windshield.
2. Bend the tips on the metal clip on the mirror mount inwords. I used my ignition key.
3. Slide the mirror mount back on the lug on the windshield.
Problem solved!!
Hope this can help.
Sent from my SAMSUNG-SM-N900A using Tapatalk
I could definitely see that happening where there is a lot of heat and UV exposure as its facing the windshield. They say the glass is 100% UV blocking on the 2012 and newer. I would not know. I live in Seattle. I have not seen the sun in 4 months. We don't have those kinds of problems. We do not get tan here, we rust!
Motzking1 is offline   Reply With Quote
Old 01-24-2017, 06:10 PM   #2
MadMax
MadMax's Avatar
Yeah, it's just the opposite here...triple digit heat for several months each year, which is why those plastic ears where the first things that went on my mirror. Luckily I got a replacement, but I know it's just a matter of time before I'll need another!
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Yaris 2011 3rd gen rear view camera problem robertkk In Car Entertainment + Electronics (audio / video / alarm) 2 06-19-2014 08:56 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
