![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Mine has the factory 15inch rims and stock size tire and 180000km and it revs out without hesitation
I dont know the weight difference of a NCP13 with a NCP91 maybe it gained a few kilos.. Stock factory figures where 0-100km/h 9 sec and 190km/h at the limiter and about 107bhp.I would still check for compression though as I am weird like that
#2 | |
![]() Drives: 2005 Vitz RS Manual Join Date: Jan 2017
Will see how it (vitz rs) behaves with 1ZZFE throttle body... Regarding compression: there is no need to check it, as it does not consume oil, there is no blow by, there is no idle issues, oil is clean etc. What I believe has happened is that Toyota was lazy and used the same CVT safe tune/throttle map on manual car. While throttle response on CVT equipped car is not important on manual car it is somewhat important (unless you hate driving). If I wanted a boring car I would have bought an automatic Tiida for half price. Regarding performance difference between two - yes Gen2 is slower than Gen1 due to 80kg difference (Gen1 950kg vs Gen2 1030Kg). This difference would not explain anaemic throttle response. What I am saying is that toyota took all the fun out from the engine with their very conservative tune. Bloody 3 cylinder Sirion is more fun to drive than this thing. Last edited by SlowVitzRS; 01-25-2017 at 06:14 AM. |
Well if emissions is not a problem in NZ maybe you should backdate your ecu and throtle to gen 1 :)
Or try those kits that remove the lazynes from the systems with e-throtle. Good luck
| 2010 Vitz RS Modellista Completed Car | Vitz Rs Modellista | Photo-Video-Media Gallery | 38 | 11-18-2014 12:25 PM |
| Toyota yaris hatchback headlight fits on Vitz 2005? | urguardian | Cosmetic Modifications (Exterior/Interior) | 2 | 09-11-2014 04:46 PM |
| Vitz 2005 Battery | mudi | General Yaris / Vitz Discussion | 0 | 09-07-2011 02:28 AM |
| Toyota Vitz 2005 1.3L Auto Air Filter | technoguy | DIY / Maintenance / Service | 4 | 01-11-2011 02:45 AM |
| Vitz 2005 in UK. | lappie | General Yaris / Vitz Discussion | 0 | 03-12-2006 10:02 PM |
