Old 01-25-2017, 06:58 AM   #1
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Quantum turbo kit on 1NZFXE NHW20...Prius?
Originally Posted by ncp13 View Post
We have a 1NZ-FE on a prius II simulator in our technical training facilities and it runs fine
no cel . The 1NZ-fxe was destroyed by a tech leaving the cam gear loose... lol
Nice Prius BTW!
Thanks for the compliment!
And you have all the same ECUs and sensors..including a HV and 1NZFXE ECU?? That is VERY interesting! If I can get another +/- 15hp just by swapping in the 1NZFE camshaft, that would be amazing!! Thx! That'll be the next thing I try once the EMU is wired in along with the turbo kit. I've been eyeballing an whole remanufactured head assembly VS a came swap. I'm already pushing 160k on this engine.
JustDidIt is offline   Reply With Quote
Old 01-25-2017, 09:02 AM   #2
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
We have a full prius II with all ecus interior confort etc. Fully functional.
ncp13 is offline   Reply With Quote
Old 01-25-2017, 09:15 AM   #3
JustDidIt
JustDidIt's Avatar
That is very encouraging. Thx for the heads up! The two engines have so much in common - except the pistons, rings, crank and cam and cam gear.
From the 1.5 1NZ-FE: Yaris, Echo, Scion xB & xA
Cam 1: 13502-21031 (Prius: 13502-21021)
Cam 2: 13501-21030 (Prius: 13501-21060)
Cam Gear: 13050-21041 (Prius: 13050-21051)
Sprocket: 13050-21041 (SAME AS PRIUS)
Timing Chain: 13506-21050 (SAME AS PRIUS)
Rings: 13011-21041 (Prius: 13011-21100)
Pistons: 13101-21070 (Prius: 13101-21110)
Rods: 13201-29735 (SAME AS PRIUS)
Bearings: all three (SAME AS PRIUS)
Cylinder Head: 11101-21062 (SAME AS PRIUS)
Even the valves are the same...
Old 01-25-2017, 08:52 PM   #4
JustDidIt
JustDidIt's Avatar
this has really peaked my interest. . .Have you ever driven a 1NZFXE prius in comparison to the one you have in the shop that has the 1NZFE?
Old 01-31-2017, 02:43 AM   #5
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Its a metal frame simulator with all of the ecus and mechanicals exposed. Its fully functional but without power steering.. I will send a picture soon :)
WTB Turbo kit ynnek317 Willing to Buy by private party 5 07-04-2014 01:53 PM
For Sale: ZPI Turbo Kit CTScott Items for Sale by private party 27 12-10-2013 06:00 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
