Old 01-26-2017, 10:49 PM   #1
7:34pm
Drives: 07 Yaris
OK. The back-up light switch is located on the top of the tranny. You will need to move the battery out of the way to get at it.
To do a quick and easy test to see if it is actually the problem, you could jump the red wire in pin 3 of connector CA1 to a +12V power source. If the lights come on when you do that, then you know that either the back-up switch is bad or its connector is corroded.
Attachment 52709
Hey I'm having the same problem and trying to figure this out. Both bulbs are good but the reverse lights won't come on.
What exactly is the bottom end of the arrow pointing to? I can't quite tell from the diagram. Also should this be done with the car on or off, or in accessory mode?
Thanks
7:34pm is offline   Reply With Quote
Old 01-28-2017, 12:24 PM   #2
7:34pm
Drives: 07 Yaris
Thanks
Nvm, just checked and the wire is broken. Going to solder it back or something.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
No parking lights ryufrank In Car Entertainment + Electronics (audio / video / alarm) 0 10-06-2013 09:28 AM
Clazzio MicroImage problems please help boggydee Cosmetic Modifications (Exterior/Interior) 1 08-24-2012 04:16 AM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
JUST GOT MY JDM TAIL LIGHTS!!!!! falkor_99 Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 11:25 AM
