Old 01-29-2017, 12:50 PM   #1
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
Originally Posted by Bluevitz-rs View Post
It's because you're using the A/C when the defrost setting is used. So it takes moisture out of the air but after years of use there can be an accumulation of dust on the evaporation coil that never dries out and gets moldy. The only way to avoid the smell is to avoid using any defrost setting. Even the mixed mode uses A/C.
I know on my Echo the setting for floor only still put air up on the windshield so I never use any defrost settings.
You're saying it turns on the compressor when you put it on defrost, even without the A/C button pushed? I've had a few GM cars which did that, but I've never noticed the compressor in my Yaris cycling on and off when it's in defrost mode.
scratchpaddy is offline   Reply With Quote
Old 01-29-2017, 05:38 PM   #2
SirDigby
Drives: 2007 yaris 3 door
almost all vehicles do this now. some vehicles you can turn it off, but I think for Toyota you have to run a switch off the ground and manually turn it off. it's so stupid.
I'm surprised you have not noticed the rpm's all over the place when idling with defrost on... it sound so horrible
Mga Bagong Kayaris ! ! ! syntax Middle East 749 04-26-2021 02:40 AM
Burnt smell in cabin at high speed in cold weather grilled cheeseus DIY / Maintenance / Service 13 12-15-2018 07:29 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
