![]() Drives: 07 Yaris HB Join Date: Jan 2017
From the top it looks fine, but I don't have the tools to pull the tire off and get a good look at it, let alone a puller tool if it was bad. I'll just wait and see what the dealership mechanic says tomorrow.
fyi, I was able to get the crank pulley off on 2 different 1nz's and one 2zr when I worked on them just by putting an air hammer to it to vibrate it loose and then just using my hand to remove it. That said I needed an impact wrench ot get the bolt on and off without a tool to lock the pulley from turning.
Just a heads up in case you ever decide to pull it yourself down the road without a puller but with air tools keep us updated on what the mechanic says
| Weird starting issue | shepd | DIY / Maintenance / Service | 7 | 03-22-2016 11:20 PM |
| Stalling and restarting issue | Yaris175 | UK | 6 | 02-12-2015 06:30 PM |
| Odd throttle issue | mr_miles | DIY / Maintenance / Service | 21 | 11-01-2014 09:20 AM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 04:20 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
