head gasket spark plug read coolant code
At the beginning of a coolant ingestion head gasket failure, the car can still run great. Spark plug will look cleaner/whiter than the others. Miss at startup may set code...I know nothing of code-setting.
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
That is very true. You should notice coolant loss.
#3 | ||
XP10 Enthusiast
Drives: 2000 Echo Coupe Join Date: Jan 2017
Checked underneath the car and the oil pan has a little leak near the oil screw, maybe that's causing that oil leak too... A bad gasket perhaps. I'll keep you guys posted.
'01 Yaris 5dr Hatchback M/T | Blue Streak Metallic [RIP] '00 Echo Coupe A/T | Absolutely Red [Still Alive] |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
| Big engine trouble (FYI)... | Goose | General Yaris / Vitz Discussion | 31 | 10-16-2006 03:43 PM |
