Old 01-30-2017, 01:48 PM   #1
Just to clarify, when I say bottom out, I'm talking about hitting the bump stops.
Old 01-30-2017, 02:13 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Gotcha. I remember having to cut them to 1.4", which was basically half the bump stop.
On Instagram
On Wheelwell
Old 01-30-2017, 03:44 PM   #3
I don't think I'm going to cut the bump stop this time around. I'd rather just bottom out on the bump stop than fully compress the dampers.
Old 01-30-2017, 04:04 PM   #4
BennyLava
Drives: 1987 Silverado
So how did your ride quality do, lazagna? Still the same as stock?
I take it none of you mean that you're scraping on anything. I may go with the 1.4" kit instead.
Old 01-30-2017, 04:15 PM   #5
With the Vios, I had the TRD Sportivo dampers. So with the combo of the two, the ride was definitely firmer than stock.
I'm used to driving lowered vehicles, so I don't really scrape on anything. However, with the custom resonator back I had on the Vios, the piping did scrape on speed bumps.
Old 01-30-2017, 07:11 PM   #6
BennyLava
Do you think that a 1.4" drop, would still be noticeable? Would it be a noticeable improvement in looks, and a noticeable improvement when it comes to the wind at highway speeds? I don't have any experience in lowering a Yaris.
Old 01-30-2017, 11:08 PM   #7
It'll be noticeable in the looks department. For crosswinds, I think spring rates would have a bigger effect than the drop amount. From what I remember some years back, the S.Tech springs had the highest spring rates of the springs (at the time I got them). You can also get wider wheels and tires to help with cross wind traction.
Body Kit Questions JohnnyBomber101 Cosmetic Modifications (Exterior/Interior) 5 05-21-2011 11:18 AM
Some 2011 body questions hoggster Cosmetic Modifications (Exterior/Interior) 3 03-08-2011 11:49 AM
New guy with a couple questions! 2slow Cosmetic Modifications (Exterior/Interior) 12 05-05-2009 08:28 AM
The Upgrade is done, couple questions regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 05-02-2009 05:25 AM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
