Old 01-30-2017, 04:04 PM   #1
BennyLava
Drives: 1987 Silverado
So how did your ride quality do, lazagna? Still the same as stock?
I take it none of you mean that you're scraping on anything. I may go with the 1.4" kit instead.
BennyLava is offline   Reply With Quote
Old 01-30-2017, 04:15 PM   #2
With the Vios, I had the TRD Sportivo dampers. So with the combo of the two, the ride was definitely firmer than stock.
I'm used to driving lowered vehicles, so I don't really scrape on anything. However, with the custom resonator back I had on the Vios, the piping did scrape on speed bumps.
Old 01-30-2017, 07:11 PM   #3
BennyLava
Do you think that a 1.4" drop, would still be noticeable? Would it be a noticeable improvement in looks, and a noticeable improvement when it comes to the wind at highway speeds? I don't have any experience in lowering a Yaris.
Old 01-30-2017, 11:08 PM   #4
It'll be noticeable in the looks department. For crosswinds, I think spring rates would have a bigger effect than the drop amount. From what I remember some years back, the S.Tech springs had the highest spring rates of the springs (at the time I got them). You can also get wider wheels and tires to help with cross wind traction.
Old 01-31-2017, 04:04 AM   #5
BennyLava
Thanks again for all the help and replies. Its very much appreciated.
Do you think I'll need to cut the bumpstops on a 1.4" drop? Also, do you think the stock shocks and struts will be ok for that much drop?
Side note: I know you recommend the S-tech, but I just can't go that low. 2" is just too low imho, for me, on this car. H&R make top notch springs, so I know I'll be in good hands with their product.
Old 01-31-2017, 09:30 AM   #6
H&R is a higher quality brand over Tein. As for the bump stops, look in the instructions in the springs to see if they require cutting the OEM bump stops, and if they do, how much.
I'm either going to not cut mine this time, or maybe just cut off 1/4 (I remember doing 1/2 of the bump stop last time).
Old 01-31-2017, 07:23 PM   #7
BennyLava
Do you know anything about using the factory shocks with those springs? Its only 1.4 inches. I guess there is really no way to know until I try it. But my hope is that 1.4" just isn't enough to bottom out the insides of the shocks/struts.
Body Kit Questions JohnnyBomber101 Cosmetic Modifications (Exterior/Interior) 5 05-21-2011 11:18 AM
Some 2011 body questions hoggster Cosmetic Modifications (Exterior/Interior) 3 03-08-2011 11:49 AM
New guy with a couple questions! 2slow Cosmetic Modifications (Exterior/Interior) 12 05-05-2009 08:28 AM
The Upgrade is done, couple questions regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 05-02-2009 05:25 AM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
