Old 01-30-2017, 10:04 PM   #1
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by miiser View Post
That's exactly what I had in my mind! I hate I really hate! Hate! This green!! I thought it wasn't possible to change it! But here you are!
How You did this??? Is it easy?
it is pretty easy. you just pull off the side plastic trim, the speedo trim. then you can take out the whole center HVAC controls. the spiral controls just pop off with a pic or pocket screwdriver. 2 are the same, 1 was different. there is a few posts with pictures if you do some searching. I don't have any of doing it, but it took like 15 minutes to do. the dash gauge is the same as any other aftermarket gauge.
you should live chat with superbrightleds.com I bet they ship to Europe. you should do a lot of research and order all the bulbs you can think of.
I forgot I DO have a LED license plate bulb. there is only 1, so it's a very good idea to do that one. and I did the little peanut bulbs in the front headlights with bluish LED tower bulbs. they come on with the parking brake set, and the switch set to "parking" or the first position. they are on with the headlights on. they are off with the DRL only. (I don't know how the headlight is set up in Europe)
Old 01-31-2017, 04:28 PM   #2
miiser
miiser's Avatar
Drives: yaris 2009
So it's easy to change the lights on the hvac? There are like plug and play? Or you have to iron solder ??
miiser is offline   Reply With Quote
Old 01-31-2017, 08:31 PM   #3
SirDigby
PnP. you just order the correct size. I forget the size, (it's a 4 digit I think) but if you do a search I know there are lists of all the bulb sizes all over this site. the speedo does require more extensive work. I have not messed with them. did you see the LED lights on www.superbrightleds.com that look like old school incandescents? super sweet!
official JOLT YELLOW Yaris thread! firebird1999us Photo-Video-Media Gallery 68 08-01-2019 05:35 AM
Cruise Control kicking itself out GTBaker Third Gen Yaris General Discussion 9 09-05-2013 09:39 PM
Test Fit $50 Or LED Tail lights winson California 6 01-05-2010 08:31 PM
DIY LED Tail (Rear) Head Lights dg4rez DIY / Maintenance / Service 11 12-21-2009 04:10 AM
LED rear lights question Danish Yaris Cosmetic Modifications (Exterior/Interior) 24 04-16-2009 02:26 PM
