Originally Posted by KTS
I think it's just an open/close switch. Doesn't matter the polarity.
First you will have to remove the cutter pin that connects the cable to the lever, then use a pliers and a screw driver to remove the lock that attaches the cable to the bracket. Those locks are difficult to remove at times. Or you could just unbolt the entire bracket.
Have you tried doing the wiring from below the car? Last time I had to extend the reverse switch wire it was much easier to do from below the car.
Sent from my SM-G920V using Tapatalk
Thanks! However the wires are chewed on the top of the transmission, about an inch away from the sensor so I think on top will be easiest.
Will give it a shot when I have time.
