Old 02-06-2017, 06:40 PM   #1
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by David C View Post
Are the 1.8L injectors intended to be used in the Yaris 1.5L 1NZ engine ?
Envoyé de mon iPhone en utilisant Tapatalk
Intended... no. But for boosted 1NZ applications and other performance modifications, the 1ZZ injectors have shown to help performance.
JustDidIt is offline   Reply With Quote
Old 02-06-2017, 10:01 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I upgraded to the green 1ZZ injectors to keep from going lean with my Blitz supercharger. If you have a proper engine management system, you can just tune the fuel map to compensate. The Blitz comes with a really basic piggyback that just makes the ECU go into open loop mode, which just dumps a ton of fuel to ensure it's not running lean. Bigger injectors = more fuel = lower AFR under boost. Not terribly elegant, but safer than running lean and breaking things.
Old 02-06-2017, 10:05 PM   #3
David C
Drives: White '07 3dr LB
Thanks
David C is offline   Reply With Quote
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
FS: DeatschWerks 550cc Plug/Play injectors Tamago Items for Sale by private party 4 06-27-2012 11:11 PM
2 sets 1nz fuel injectors for sale fnkngrv Items for Sale by private party 2 06-05-2012 05:35 PM
200cc Vs 240cc Fuel Injectors SL Runner Performance Modifications 2 09-07-2011 05:08 PM
