Old 02-10-2017, 06:09 AM   #1
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Not even 1 liter / 1000km shows clouds of blue smoke..
Check the condition of your engine to figure out if your oil consumption is from worn piston/rings/cylinder, valve seals .
Compression test , leak down test , pull a spark plug and see inside or on the spark plug for heavy oily residue.
Thick oil is just a temporary bandaid and might work for an engine with loose tolerances .
good luck.
ncp13 is offline   Reply With Quote
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 09:28 PM
