Old 02-10-2017, 09:34 AM   #1
Ewer678
Drives: toyota yaris vvt 2008 automati
Stuck in first gear
Hi I own a 2008 yaris vvt automatic. Yesterday I started the car it would rev but not go as if it was not in gear. I turned off ignition and restarted it, only to find the car was stuck in 1st gear. Tried moving gear stick from drive to reverse and back to neutral without success. Eventually I went into the manual gear change and got the car to change to 2 be gear and back to neutral where the car started for me. My question is, is there anything I can do to stop this reoccurring and does this mean my gear box is on its way out. Any ideas thanks
Ewer678 is offline   Reply With Quote
Old 02-11-2017, 10:32 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
I forgot the name of this, but there is a switch by the gearbox that tells the computer which gear you are in. This might be defective.
Old 02-12-2017, 08:02 AM   #3
Ewer678
Thanks if it persists I will mention it to my mechanic
P0705: Yaris 2008 stuck in first gear in D position eepp DIY / Maintenance / Service 3 01-22-2018 12:24 PM
Stuck in 2nd gear! Surubi Suggestions - Feedback - Questions 3 03-01-2015 04:17 PM
Car got stuck in gear? mr_miles DIY / Maintenance / Service 1 03-24-2012 12:25 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
Yaris seems to get stuck in 3rd gear when going uphill 47_MasoN_47 General Yaris / Vitz Discussion 16 08-24-2009 01:22 PM
