Old 02-11-2017, 02:10 PM   #1
cabinfevrr
Drives: 2008 yaris 5door RS
There has to be a simpler way. How do you trick the immobilizer when you have a remote starter?
cabinfevrr is offline   Reply With Quote
Old 02-11-2017, 02:44 PM   #2
You use a transponder key bypass module, which either requires surrendering a key into a little box that gets hidden under the dash or programming the module by reading an existing key.
Old 02-11-2017, 03:07 PM   #3
cabinfevrr
Do you think that could solve my problem, or do you think there are bigger issues in play?
Old 02-11-2017, 09:07 PM   #4
Do you have a second key, as that will tell you if the issue is the key or the transponder key amplifier?
Old 02-11-2017, 09:11 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
If the immobilozer isn't reading the key, it would simply not start the car right? It wouldn't start and die within 2 sec. Once the key has been read and car started, it doesn't need the transponder anymore.
Old 02-12-2017, 05:50 AM   #6
cabinfevrr
I have a dummy key I got cut just for the doors, and if you try to start the car with it, it will start but after a second or two it will die.
Old 02-12-2017, 05:48 AM   #7
cabinfevrr
I have all 3 factory keys - one with remote, black one and grey valet key. This behaviour is not key specific, it will do this with all 3 keys.
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Where is the transponder chip? rcvmini In Car Entertainment + Electronics (audio / video / alarm) 3 03-04-2014 09:36 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 05:04 AM
Dashboard display and transponder AlanSilberlight General Yaris / Vitz Discussion 0 04-13-2012 07:24 PM
Yaris transponder key: do we ALL get one?? auxmike DIY / Maintenance / Service 10 12-01-2008 10:40 PM
