Old 02-15-2017, 08:00 PM   #1
tmontague
tmontague's Avatar
Can you confirm if you have to remove the head to remove the rooming cover? When I replaced the head gasket on my echo I have to remove the timing cover to remove the head but I'm pretty sure the head can stay in when the timing cover is removed.
Just want some clarification
Old 02-16-2017, 01:04 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
My garage removed the head cover when they did the timing chain cover. So they did the head gasket at the same time.
Sent from my SM-G930W8 using Tapatalk
Old 02-16-2017, 01:07 PM   #3
B.B._07
Drives: 07 5dr
To remove the timing chain cover or oil pump (the oil pump is built into the timing chain cover) you need to remove the valve cover but certainly not the head. If you're getting a leak from the timing chain cover area it could also be the crankshaft seal.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
