Old 02-21-2017, 12:38 PM   #1
Corbeaubleu
Drives: 2005 Echo RS HB, 1996 VFR750,
Looking at Montagues first engine bay photo, the 1NZ seems to have the same clearance to the sub frame as on the Echo. I'd need a dimension from bell housing to crankshaft pulley to know for sure.
Right now, I've got reservations about the harnesses: the Echo doesnt have the same throttle body as the Yaris, so what else is different? Do we have pin code charts on this site?
Corbeaubleu is offline   Reply With Quote
Old 02-21-2017, 12:56 PM   #2
Start your own thread on this as it is its own standalone subject. OP does not need this pollution in his build thread.
Moderators should pull all the posts relevant to an Echo swap out and establish a thread for you.
Old 02-21-2017, 01:11 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Ha, good one.
On Instagram
On Wheelwell
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
