Old 02-21-2017, 06:27 PM   #1
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
I'm guessing your removing the crankshaft sensor or camshaft sensor. Not sure by your explanation. But they are necessary to the computer to know if you have a misfire. So if you have a catalyst damaging misfire removing one of the sensors would make it impossble for the computer to know the rotation of the crankshaft hand or camshaft position therefore making it unable to set a misfire code.
Back up a few steps and do what B.B._07 says. Put on the scanner. Clear the codes. And start from the beginning. Start the car. When the light flashes turn it off and check the codes.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
