Old 02-27-2017, 02:05 AM   #1
JSCIII
Drives: Yaris Hatchback 3 Door USA Ver
Originally Posted by Bluevitz-rs View Post
Try disabling the power to the EPS. If your problem disappears there's probably issue with the steering angle sensor or load sensor.
Spot-on!!! Took out the angle sensor and found a short-circuit, cleaned the component and mounted back everything, issue is gone! Thank you folks!! 👌🏼👌🏼
JSCIII is offline   Reply With Quote
Old 02-27-2017, 09:04 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Tags
2008, eps, hatchback, steering issue, yaris
steering problem redgreen DIY / Maintenance / Service 31 09-18-2015 08:20 PM
First post from Yaris noob... Steering wheel and double din? Ash187 Cosmetic Modifications (Exterior/Interior) 1 09-08-2013 02:19 AM
WTB Yaris electric steering column + steering ecu ayashifx55 Willing to Buy by private party 6 04-04-2013 03:41 PM
