![]() Drives: Toyota New Yaris Sedan GLI 201 Join Date: Dec 2012
Pressure tires 205/50 r15
Hi friends
I need to know how much pressure I could use in my tires ContiPremium Contact 2 05/50 R15... (before I have 175/65 R14, changed by R15) I have a New Yaris Sedan 2013 GLI Thanks, regards from Chile Sorry for my english |
it does not matter the size. pressure is pressure.
the question is, what is your altitude? sea level pressure is 30psi 3000 ft. (1000m) is about 32psi 5000 ft. (1500m) is about 33-34psi 7000 ft. (2100m) is about 34-35psi 10000 ft. (3050m) is about 36psi |
30psi? It really depends on the tire. I run Yokohama s.drive tires and they really need 35-38psi to wear evenly. And I'm almost at sea level.
Sent from my SM-G930W8 using Tapatalk |
#4 | |
https://en.wikipedia.org/wiki/Los_Andes,_Chile |
#5 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
I run 205/45R16 with 30-31psi front and 26psi rear. I usually make a chalk marl on the sides and drive the car on and off highway then look at the wear mark off the chalk. I then adjust accordingly + or -. |
#6 | |
I think the pressure depends more on the vehicle than on the tire or not?++ Because if a tire of a measurement, I use it in different cars, the weight changes therefore another pressure |
I was just starting with the door sticker setting and adjusting for loss of pressure due to altitude, but temperature and humidity can also make slight changes. here's a chart:
| Winter tires and road hazard program w/Tire Rack | mikey4226 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-04-2012 12:07 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| Boring Tires Recommendation | DaveG | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 07-16-2010 05:18 PM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 07:58 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
