Unplug the stock tweeters. Or if you get components, do replace the stock tweeters with the components pair.
What car do you drive to have tweeters? Afaik, no yaris have them? Sent from my SM-G930W8 using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
Sound-speaker guru needed!
I have a 2009 hatchback Europe model and it has tweeters. They are triangles in the front near the widescreen. Any way, why should I replace them? They are good already as is :/ Sent from my iPhone using Tapatalk
#3 | |
Well, tweeters in a component set are made to work together. If you don't use them and install your own, then it might sound bad. Although, if you are tone deaf, you wouldn't really notice it. Also, if your new jvc door speakers have tweeters built-in, then you definitely should unplug the tweeters in the pillars. Again, it's made to work like this by design. Sent from my SM-G930W8 using Tapatalk |
#4 | |
Well if I buy components I will put the jvcs in the rear. So I will have 2 tweeters in front and 2 in the rear. But can my system handle it?? Sent from my iPhone using Tapatalk |
#5 | |
If the rear also have separate tweeters, then the should be disconnected. Sent from my SM-G930W8 using Tapatalk |
| 2007 hatchback making a weird whirring sound | robkay | DIY / Maintenance / Service | 20 | 03-19-2016 06:53 PM |
| Squeaky sound | Mikastef | DIY / Maintenance / Service | 2 | 03-28-2015 01:56 PM |
| Spacer Template for Hatchback Aftermarket Speaker Install | bigsky2 | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-12-2014 01:53 PM |
| 6 speaker setup and speaker sizes | jstantherprsn | DIY / Maintenance / Service | 0 | 12-09-2010 11:21 AM |
| Speaker Rattling | kylemhall | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:24 AM |
