![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
Sound-speaker guru needed!
Ok this is what I have found:
For the soundproof plan: https://www.amazon.com/gp/aw/d/B012A...NOZL83GP&psc=1 For the component plan: https://www.amazon.com/gp/aw/d/B0007...D8L&ref=plSrch Or these pioneers (that they are double the price): https://www.amazon.com/gp/aw/d/B014X...dtL&ref=plSrch Also another question: Can I place bass speakers (like the ones that are on a sub) in the door??? Like this for example: https://www.amazon.com/gp/aw/d/B00I3...1IL&ref=plSrch Or https://www.amazon.com/gp/aw/d/B00BQ...ss+speaker+6.5 Sent from my iPhone using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
First thing first, you can't get more sound without supplying more power. Your stock head unit (as well as most aftermarket ones) will only be able to output about 50w per channel (200w for 4 speakers) and that's peak power. Real power, the RMS, is about half, so 25w RMS per channel. That means even if you buy a 200w RMS mid bass speaker, you'll never be able to drive it to more than 12% of its full power, and that's with cranking the volume all the way up. So the bass won't hit much more. The only thing you'll gain will be the possibility of producing the lower frequencies that your current setup can't, but since you won't be able to produce them with enough power, you won't hear them anyway. Which means you would need an amp. However you could wire the mid bass speakers in parallel on two channels each (left front with left rear and tight front with right rear) to get them to receive twice a stronger signal, but still I'd doubt you make anything buzzing without cranking it up to a very unpleasant volume. I'd stay away from low budget speakers if you plan to invest into a decent sound experience. Instead stay alert and find good deals on higher quality speakers. But again, as good as your door speakers may be, they'll always leave you lacking depth in the sound, because there's no good resonance structure to direct the sound. Envoyé de mon iPhone en utilisant Tapatalk |
| 2007 hatchback making a weird whirring sound | robkay | DIY / Maintenance / Service | 20 | 03-19-2016 06:53 PM |
| Squeaky sound | Mikastef | DIY / Maintenance / Service | 2 | 03-28-2015 01:56 PM |
| Spacer Template for Hatchback Aftermarket Speaker Install | bigsky2 | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-12-2014 01:53 PM |
| 6 speaker setup and speaker sizes | jstantherprsn | DIY / Maintenance / Service | 0 | 12-09-2010 11:21 AM |
| Speaker Rattling | kylemhall | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:24 AM |
