Old 03-04-2017, 11:12 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by miiser View Post
I have a 2009 hatchback Europe model and it has tweeters. They are triangles in the front near the widescreen.
Any way, why should I replace them? They are good already as is :/
Oh ok.
Well, tweeters in a component set are made to work together. If you don't use them and install your own, then it might sound bad. Although, if you are tone deaf, you wouldn't really notice it.
Also, if your new jvc door speakers have tweeters built-in, then you definitely should unplug the tweeters in the pillars. Again, it's made to work like this by design.
Old 03-04-2017, 11:23 AM   #2
miiser
miiser's Avatar
Drives: yaris 2009
Originally Posted by IllusionX View Post
Oh ok.
Well if I buy components I will put the jvcs in the rear. So I will have 2 tweeters in front and 2 in the rear. But can my system handle it??
miiser is offline   Reply With Quote
Old 03-04-2017, 02:31 PM   #3
IllusionX
You would install the component tweeters in place of the original ones.
If the rear also have separate tweeters, then the should be disconnected.
2007 hatchback making a weird whirring sound robkay DIY / Maintenance / Service 20 03-19-2016 06:53 PM
Squeaky sound Mikastef DIY / Maintenance / Service 2 03-28-2015 01:56 PM
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
6 speaker setup and speaker sizes jstantherprsn DIY / Maintenance / Service 0 12-09-2010 11:21 AM
Speaker Rattling kylemhall In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:24 AM
