Old 03-05-2017, 11:40 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Leave the weight of the car on the struts to loosen the top nut
Old 03-05-2017, 11:53 AM   #2
Pinchlite
Drives: 2007 yaris HB
I got it off and reassembled....dont even ask how.
Know the issue is that even after cutting 1.5 inches off of bumpstop I think the shock top plate thingy is resting on the bumpstop after putting on tire and lowering to ground.
I may cut 2 inches off the next,then I will have to remove the first and cut another 1/2 inch off aswell.
The car doesnt seem to have lowered near as much as the back..looks stock to be honest.
could this be because the other side was still at stock height with stock spring?
Really,really frusturated.
UPDATE:
Tried to loosen the top nut and know the strut shaft allen key hole is stripped.
Looks like I will need to get it towed to a shop know because cant drive it with different shocks on each wheel.
Unless anyone has any suggestions.Not enough meat above the nut to get vicegrips either.
What a bloody nightmare.
Pinchlite is offline   Reply With Quote
Sway Bar End Links Help! GiovanniVan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-02-2015 11:14 PM
How should the front sway bar be positioned when adjusting coilovers? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-28-2011 11:20 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
