Old 03-05-2017, 12:06 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I had to use a sawzall to get them off the swaybar, then took them to my workbench and used a grinder to remove the upper nuts.
Old 03-05-2017, 12:19 PM   #2
Pinchlite
Drives: 2007 yaris HB
Stripped top shaft allenkey hole on strut
I already got that off by destroying boot using vicegrips.Will need new swaybar links obviously.
MY ISSUE KNOW is the top strut piston shaft allen key hole is stripped.
Looks like I will be taking the day off of work tomorrow.
Pinchlite is offline   Reply With Quote
Sway Bar End Links Help! GiovanniVan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-02-2015 11:14 PM
How should the front sway bar be positioned when adjusting coilovers? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-28-2011 11:20 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
