Old 03-05-2017, 06:13 PM   #1
tmontague
tmontague's Avatar
As WeeYari stated, always having a can of PB Blaster or equivalent and spraying the bolts early will help. Or make your own out of transmission oil and acetone and put it in an oil drip can.
You won't be on the bump stops as their is more travel from the factory then you removed installing your lowering springs. I only trimmed my bump stops about a half inch and I'm not even riding on them. if you were every little bump would feel harsh and very slightly dampened.
Riding on the bumps is not really an issue (unless you cut them) Mini cooper S's come riding on the bumps from factory. Makes for a terrible DD but a damn fun go cart on the on ramps ;). In their newer models they decided away from this and softened up the suspension.
Old 03-05-2017, 06:17 PM   #2
Pinchlite
Drives: 2007 yaris HB
Bump stop
I cut 1.5 off as recommended by manufacturer when using stock style struts.
Pinchlite is offline   Reply With Quote
Sway Bar End Links Help! GiovanniVan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-02-2015 11:14 PM
How should the front sway bar be positioned when adjusting coilovers? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-28-2011 11:20 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
