Old 03-06-2017, 01:38 AM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Originally Posted by David C View Post
I'm not an audio engineer, so I won't try to argue on your speciality. I agree with you that you can only get better sound by using better speakers, that's a fact.
As you pointed, if your end goal isn't to reach a nice and deep sound experience inside your car (boomy and clear, without going crazy expensive or comp level), then swapping two of the 4 doors speakers with mid bass ones and wiring them in parallel with the front speakers to help drive them to a better output level (if desired/needed) and using the front door speakers as mid range, and tweeter up front, then properly tweaking the signal sent to each speaker by using the head unit settings and physical crossovers could get you a nice sound for cheap. However you may not be able to recreate that level of sound clarity when you start driving on the free way due to road noise and poorly sound proofing of the Yaris. Even with my setup you can start loosing some of the end of both high and low range with you drive past 100km/h. That's why sound proofing would help a lot too.
Did you upgraded the door speaker wiring when you changed the speakers ?
Your recommended approach is certainly the better one overall, it's just a matter of how much you want to spend.
FYI in my 2nd gen Yaris I don't have any other front speakers apart from the two in the doors. So this is a somewhat different situation from the OP's car. I get lots of bass, and generally have to keep the bass control fairly low on the head unit. IMO having tweeters on the dashboard would improve top end presence that bit more. Having them project toward my knees, the way they are right now, isn't really ideal.
I haven't upgraded the stock Toyota speaker wires, as IMO that's quite unnecessary in this application. However, for my 100W RMS/channel home system, I use some huge fat speaker wires. :-)
Sent from my phone with Tapatalk. Please excuse any typpos.
tarkus is offline   Reply With Quote
Old 03-06-2017, 02:23 AM   #2
miiser
miiser's Avatar
Drives: yaris 2009
Sound-speaker guru needed!
What speakers do you have? I mean the exact model if you remember it.
Your situation is different than mine. In your case you have 4 speakers on the front. Coaxials count as 2 each, cause they have build in tweeters in the middle of the speaker. So you have 2 mid bass (the speaker itself) and 2 highs (tweeters).
In my case I have 6 speakers in the front now. And 4 of them are tweeters (2 pillar tweeters and 2 on the speaker) and this eliminates all my bass. Tbo after a week of using them I really think they sound better that the beginning. Maybe I got used to it, but maybe when speakers are new they need some time to produce the proper sound.
Anyway, I don't believe that my speakers are bad. I searched for them before I bought them. And they had very good reviews.
I just need something to spice the sound even more. Guess I should have bought component speakers from the begging, but I am a newbie on the sound industry, so i am just learning and making my first steps. Plus I bought these cause they came up with adapters too, wirings etc, in a very good price.
miiser is offline   Reply With Quote
2007 hatchback making a weird whirring sound robkay DIY / Maintenance / Service 20 03-19-2016 06:53 PM
Squeaky sound Mikastef DIY / Maintenance / Service 2 03-28-2015 01:56 PM
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
6 speaker setup and speaker sizes jstantherprsn DIY / Maintenance / Service 0 12-09-2010 11:21 AM
Speaker Rattling kylemhall In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:24 AM
