Old 03-06-2017, 12:54 PM   #1
ysar
Drives: 2007 Yaris
Cold box? What's that?
Didn't realize you still drive the car on the road (didn't think it would be legal due to the roll cage). How much more weight do you have to add to be class legal? Aren't you still adding more to the cage, so that should add some weight. Does the TRD kit you got have the rear sway bar? If not, that should add a few lbs. And good idea about balancing out the weight distribution by the spare tire.
I have no knowledge on track/auto-x racing, btw, so I have no clue what parts are legal and not legal in classes.
I'm only 35 lbs under weight. Fuel and tire should do it.
I'm not running the rear ARB because it's not part of the kit.
ysar is offline   Reply With Quote
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
SCCA Houston Region B Spec build :) FHT_Racing Tracking, Racing, Auto-X Forum 126 11-11-2014 01:08 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
