#73 |
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
![]() Sent from my SM-G935T using Tapatalk |
#74 |
![]() Drives: 05' Honda S2k, 15' Toyo Yaris Join Date: Feb 2017
#75 |
![]() Sent from my SM-G935T using Tapatalk Right side in the projector left is regular |
#76 |
#77 |
#78 |
@Yaris874
Thanks for the good info and pictures. If you can get us some night time photos as well. I'm thinking of going this route now |
#79 | |
#80 |
#81 |
Thanks
#82 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() this is all low beam I Google how height to aim the lights they said 25 feet 3.5 height ??? They look high I haven't connected the high beam am waiting for the cables I put some pictures of high beam when I get it Sent from my SM-G935T using Tapatalk |
#83 |
![]() Drives: 2007 yaris 4 door basic Join Date: Feb 2014
874 thanks for your time and efforts in getting the pictures... definitely considering them, just have to get the ballasts and relay's and all the other stuff!!!
#84 |
@yaris847 they look great! Light scatter isn't as bad as without the reflectors. Any lighting experts can weigh in on the height?
#85 |
Park on a level surface parallel to a wall (driver side to the wall). Adjust driver side headlight until the cutoff is on a slight decline (ideal is 1* downward). Then park perpendicular to the wall on a level surface (farther the better to be around 30 feet away). Adjust passenger side headlight so that the top portion of the stepped cutoff of the driver side matches the passenger side's stepped cutoff.
You've just now adjusted your headlights based off your car's ride height so that it doesn't blind on coming traffic. |
#86 |
So based on 874's third pic down (provided the ground is level, which is hard to tell), it looks like his driver side headlight is at least +10*. Given he's gone for the the double stepped cutoff (top part of the driver side is in line with the passenger side bottom), potentially blinding on coming traffic pretty bad. Again, it could just be that road is going down hill in the third pic.
#87 |
So this is everything I got from ebay except the ballast because I had some
![]() ![]() ![]() ![]() Sent from my SM-G935T using Tapatalk |
#88 |
#89 |
ok so I when to one of my friends gas station the they do inspection stickers the is 12 feet from the wall 25" from the floor Sent from my SM-G935T using Tapatalk |
#90 |
As long as it ends up being a declined angle. Also decided on a single step vs a double step adjustment?
| Having a few very very odd issues after LED conversion | Astroman | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 08-03-2014 05:53 AM |
| Does anyone realize yarisworld is getting 'less busy'? | caineroad | General Yaris / Vitz Discussion | 84 | 11-05-2013 12:19 AM |
| FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video | V70R_Blackbrick | California | 4 | 10-13-2013 10:57 PM |
| Yari gets a sway bar and a rim change (again) | D&D | Photo-Video-Media Gallery | 8 | 09-16-2013 01:10 AM |
| Cruise Control kicking itself out | GTBaker | Third Gen Yaris General Discussion | 9 | 09-05-2013 09:39 PM |
