Old 03-07-2017, 05:44 PM   #1
shepd
Drives: 2007 Yaris 5 door RS
There are also electronic devices you can build to simulate post cat O2 sensors, using a 555 timer. Might be a solution if pulling it out of the stream doesn't work.
Check rockauto for parts, you might be surprised at the pricing. For your 05 echo there is one as low as $231 CAD. Shipping can be pricey, though. You could have it shipped to a kinek point in Niagara Falls NY, or they will ship it to your house with the HST prepaid (so no BS UPS fees) but that could be expensive. Check the shipping on all of the converters because some of them are very expensive to ship based on region they come from. Eastern Catalytic was a good choice for the last one I bought (I still have it but it won't fit an 05 echo).
This year they got rid of the repeat conditional pass and they have gotten rid of the 1 non-ready sensor exemption, so you need to choose a permanent solution! :) And yes, you can go and get a pass up to 1 year early and it will still count. So on a suspect car, get it checked the day after your place sticker renewal!
Best of luck! The entire test is electronic now and I've never seen them put any effort into looking for any cheat devices so do whatever you must to beat the system. If you have no check engine light and a scanner says all the sensors are ready, you are guaranteed a pass. :)
Old 03-07-2017, 06:03 PM   #2
tmontague
tmontague's Avatar
When did that change? I checked online a few months ago and you're still allowed 1 ready check to be not completed. No cel can be on but 1 not ready status is allowed. At least that is how I passed last year.
If that has in fact changed please post a link if possible as this is definitely important to know for those of us with this test!
Old 03-07-2017, 10:57 PM   #3
shepd
Have a look here. The section on Not Ready no longer includes any exceptions, so 1 not ready should equal not ready at all now. Things changed in October for that.
https://www.ontario.ca/page/drive-clean-test
Readiness Changes
As of October 3, 2016, readiness conditional passes will no longer be issued.
You will be re-directed to a two-speed idle tailpipe test if all of the following conditions are met:
Your vehicle has received two consecutive “not ready” test results
48 hours or more have passed between each test
Your vehicle has been driven at least 40 km between the tests
Your battery has not been disconnected and the OBD codes have not been cleared in the last 40 km of driving
The number of “not ready” monitors has not increased during the second test
You do not have all of your non-continuous monitors in a state of “not ready” at the second test
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 11:29 AM
Engine light came on but seems to run fine naossoan DIY / Maintenance / Service 7 06-10-2013 04:51 PM
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 05:10 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
