Old 03-15-2017, 11:40 AM   #1
MadMax
MadMax's Avatar
I know this is an old thread, but I just replaced that weatherstrip on the driver's door of my 08 liftback and it took me less than five minutes to do it. First, roll down the window then carefully slide a knife blade under the old strip towards one of the two ends (the rear one is probably easier), and lift up until it pops out. Once you have some of it out, pull the rest with it. There are three (I believe) points where it is snapped into place. Once the old one is out, position the new one in place and push down on it with the palm of your hand. You should hear it snapping into place. It's that easy!
Cheers! M2
Old 05-30-2017, 04:59 PM   #2
MyzticZ3r0
Cheers! M2
Hey Madmax, the part # for the weatherstrip is 68210-52130. Correct?
MyzticZ3r0 is offline   Reply With Quote
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 11:37 PM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 11:03 AM
Electronic Window Closer mod cali yaris In Car Entertainment + Electronics (audio / video / alarm) 8 11-11-2011 12:16 PM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 7 09-22-2010 03:22 PM
underhood weather stripping drifto General Yaris / Vitz Discussion 3 04-18-2007 10:36 PM
