Old 03-15-2017, 11:53 AM   #8
MadMax
MadMax's Avatar
OK, I know it's an old thread, but in case anyone with the same problem finds it I will tell you how easy it is to replace this part. Simply roll down the window then carefully slide a knife blade under the old strip towards one of the two ends (the rear one is probably easier), and lift up until it pops out. Once you have some of it out, pull the rest with it. There are three (I believe) points where it is snapped into place. Once the old one is out, position the new one in place and push down on it with the palm of your hand. You should hear it snapping into place. It's that easy!
Cheers! M2
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 01:34 PM
Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) chalked Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-26-2013 03:29 PM
I need help locating a part...can anyone help? detroiter General Yaris / Vitz Discussion 3 08-04-2010 11:33 PM
2008 OEM S model Liftback Lip kit Part numbers PETERPOOP Cosmetic Modifications (Exterior/Interior) 17 07-26-2010 02:33 PM
NEED HELP - Yaris suspension part Trish General Yaris / Vitz Discussion 10 11-07-2009 02:44 PM
