![]() ![]() ![]() Drives: 2017 VW Jetta 1.4L Manual Join Date: Feb 2009
Mobil 1 Extended Performance 5w-30 synthetic motor oil.
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Dino oil breaks down and leaves sticky gunky residue
![]() Drives: 2007 1.3L AWD (auto) Vitz 5 dr Join Date: Aug 2020
I'm interested in why and how you can say this. Every oil, dino or synthetic, has a lifespan — does it not? So if you change out dino lube on schedule — ie: before it fails, why should it not be OK? Even dino oil has detergents and agents in it that are the developments of research and chemistry.
And BTW: I for one won't put an all synthetic oil into an older engine that has been running dino all it's life. I've seen the proof of how old gaskets can begin weeping, and I've read why it happens. But that's just me with the evidence on the garage floor. YMMV. |
#7 | |
I have not shared the same leaking experience as you when switching from exclusively conventional to synthetic. The only leaks I've had likely would have occurred regardless of what oil was in the sump.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
