Old 03-18-2017, 12:34 AM   #1
wooverstone8
wooverstone8's Avatar
Originally Posted by CB900F2 View Post
How many KM or Miles do you run the extended oil?
Usually at 5,000 miles, but I've gone up to 7,600 miles before changing it.
Old 03-18-2017, 01:47 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Then your wasting your money. A quality synthetic should be able to double that. If your changing so soon stick with dino, it's cheaper.
Old 03-19-2017, 11:58 AM   #3
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Dino oil breaks down and leaves sticky gunky residue
ncp13 is offline   Reply With Quote
Old 08-26-2020, 02:30 PM   #4
lorne
Drives: 2007 1.3L AWD (auto) Vitz 5 dr
I'm interested in why and how you can say this. Every oil, dino or synthetic, has a lifespan — does it not? So if you change out dino lube on schedule — ie: before it fails, why should it not be OK? Even dino oil has detergents and agents in it that are the developments of research and chemistry.
And BTW: I for one won't put an all synthetic oil into an older engine that has been running dino all it's life. I've seen the proof of how old gaskets can begin weeping, and I've read why it happens. But that's just me with the evidence on the garage floor. YMMV.
lorne is offline   Reply With Quote
Old 08-26-2020, 06:22 PM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yeah, to meet the API standards, conventional oils can't gum up unless exposed to extreme heat or severely extended intervals. Most engine applications wouldn't be able to push a conventional oil to its limits under normal or even hard conditions. I run synthetics in my car largely because I can buy them now for virtually the same price as conventional and it's nice insurance if I happen to run the oil in the pan longer than normal. I do like to have a synthetic for my turbo given the potential extreme heat and pressure conditions in the center rotating assembly.
I have not shared the same leaking experience as you when switching from exclusively conventional to synthetic. The only leaks I've had likely would have occurred regardless of what oil was in the sump.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
