Old 03-16-2017, 11:08 PM   #1
guybloom
Drives: Toyota Yaris
195 45 17 on a 17x7 wheel
Hello
was wondering if anyone has tried this combination and can comment.
I live in Australia where only summer tires are required.
guybloom is offline   Reply With Quote
Old 03-17-2017, 09:46 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If you're just going for look they should fit fine.
Old 03-17-2017, 11:08 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Haven't tried it, but it will certainly fit; OEM fitment is 205/45/17. Curious why you're thinking about this oddball size?
Old 03-17-2017, 07:58 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
You didn't mention what year Yaris you have, but this is pretty close to original diameter.
NSW road rules:-
You are allowed to fit wheels up to 26mm wider than original.
You may increase the vehicle track by up to 26mm.
You may change the overall tyre/wheel diameter by up to 15mm.
The wheels and tyre must not rub on any part of the body or suspension throughout the full range of motion.
If you go outside these rules, you need to get an engineer's certificate that the vehicle is roadworthy, register the certificate with RMS and keep it in the car at all times. Also make sure the insurance company knows about the new wheels.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 03-17-2017, 09:13 PM   #5
kimona
kimona's Avatar
OEM: 17x6.5, 205/45/17 = 24.3 (616mm) dia.
OP's plan: 17x7.0, 195/45/17 = 23.9 (608mm) dia.
Old 03-18-2017, 05:02 AM   #6
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Not here in Australia. Factory fit is 14x5, 175/70/14 or 15x5, 175/65/15
Old 03-18-2017, 05:48 AM   #7
guybloom
I guess I am thinking of pure looks. I think 17 inch would stand out. I would rather go with 17 x 6.5 but it's exterely hard to find any of this in Australia.
My Yaris is a 2009 Yaris with stock suspension and 185 60 15 original.
Old 03-18-2017, 05:51 AM   #8
guybloom
205 45 17 is too big will rub and will be very heavy
Old 03-18-2017, 12:57 PM   #9
kimona
kimona's Avatar
205/45/17 is OEM factory fitment, and it doesn't rub on stock suspension.
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 05:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
FS/FT/IL>JDM Gewalt Evo 3pc Wheel 4x100 17x7 +35 raytrix Items for Sale by private party 9 09-17-2011 04:10 PM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
