Old 03-21-2017, 12:15 AM   #8
SirDigby
Drives: 2007 yaris 3 door
wait...did you say removing weight on crank to offset ADDED weight to piston/rod? that is exactly opposite of correct. I believe technically you add weight to one side of a circle, you have to add weight to the other side to balance. if you add weight to one side and remove weight from the other, it would become more unstable, eh?
