it must have a different motor installed. our motor is at rest on the left and rotates clock-wise. in this set up it would only wipe the small corner and rub all down the side. logically it probably has some other motor mounted that rotates counter clock-wise. or maybe you can take the motor apart and switch the direction somehow. that would be interesting...
#2 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
How the resting position is know,horizontal bottom of window the blade is not resting on heated part of window. |
| P1 rear wiper arm on P2 | Chariz | Cosmetic Modifications (Exterior/Interior) | 1 | 10-12-2014 06:08 PM |
| Rear wiper doesn't make full contact with window. How to fix? | Silverkarn | DIY / Maintenance / Service | 2 | 06-09-2014 08:50 PM |
| Rear Wiper "Coverage" Problem Solved | Onwrdigo | Third Gen Yaris General Discussion | 5 | 06-20-2013 06:48 PM |
| Removing rear wiper | fred812 | Cosmetic Modifications (Exterior/Interior) | 34 | 01-27-2013 12:22 AM |
