![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
Headers... Are they worth it?
I am having a hard time convincing myself shorty headers for the Yaris offer much from the threads here. My 2012 5dr 5 Spd SE is a little doggy compared to my stripped down 07. Looking for a little pep.
Imo it was a worthy mod to do, aided in lowering the torque curve by about 500 rpm and seemed to help a bit in the higher rpm with extra torque/hp. The 1nz will still fall flat above 5500rpm but not much can be done about that with aftermarket bolt ons
Good mid range hp boost. With intake and a full exhaust it helps the car pull all the way to redline
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Did the gas mileage be affected with aftermarket headers?
Even without being able to tune?
Yes. Front to back, air in/air out needs to be addressed in order to realize appreciable gains. Standalone, intake, header, exhaust modifications really don't do much. It really needs to be done as a package.
the harder you drive, the more gas you'll use
oh yes. it's noticeable.
Got it, good to know, thank you both.
![]() ![]() Drives: Yaris Join Date: Oct 2017
I just don't see how aftermarket headers especially the Megan ones would gain anything compared to stock.
I took at look at the stock and it's actually a header not a manifold. For headers to provide gains, it would need to increase velocity. People are so concerned about "flow" and restrictions when exhaust is not really affected by neither too much as it's pulses rather a flow. So anyways, lol I decided not to get headers unless you go with a full length type that puts the collector further away and actually increase scavenging and velocity. Lastly, I would still get the Megans and the likes if the header was visible from the engine bay, at least it would look pretty haha! |
^although I do agree with you with a lot of your points, push the 1nz up above 5k rpm and then do so with a DC sports header and you'll start to see the difference. The larger diameter of the DC header aids in the flow. at 5k+ rpm the pulses are a lot less of a pulse and more of a flow and this is where the restriction comes into play.
With an aftermarket header you may lose low end torque but if you rev it out a lot top end can be improved
DC headers are 4-1 and technically extends the collector 2-3" (never seen in person so don't know the exact measurements.) So that's probably where you will see some gains.
Losing low end torque with aftermarket headers has to do with primary size. If Megan and DC use larger primaries then you are slowing down the velocity as it exists out the exhaust port. And the gains are gained up top where as you say "flows" more gases can take advantage of the larger primaries. If you want the best header possible it would be stepped (oe size at port, larger few inches back and a collector down low.) |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I run a port matched WeaponR header on mine.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
#14 |
#15 | |
the word "manifold" means a pipe or tube that branches off/collects together. the exhaust ports on the engine collect together at the exhaust manifold. it does not matter what it is made of. the intake manifold branches off individually to the intake ports. an aftermarket intake manifold that's made of a different material is not called a...? idk. to me, "header" is just a slang term. "manifold" means manifold as it does in electrical, as it does in HVAC, as it does in plumbing. idk. maybe i'm just crazy.... |
| DALLAS/FT. WORTH YARIS CLUB NOW FORMING! | us13doolittle | Southwest | 24 | 05-31-2018 06:08 PM |
| DC Headers question | oliveskate | Performance Modifications | 9 | 04-27-2012 09:34 PM |
| Headers | Maitre_Te_Te | Performance Modifications | 15 | 03-02-2011 10:48 PM |
| MEGAN HEADERS! < group buy price! | C2AUTOSPL | Sponsors Classifieds Area | 20 | 09-17-2007 01:54 PM |
| Exhaust Headers. Worth it? | OgDogg | Performance Modifications | 4 | 12-31-2006 09:14 PM |
