Old 04-05-2017, 09:39 PM   #1
Pinchlite
Drives: 2007 yaris HB
middle ground
Originally Posted by tmontague View Post
Fwiw if you want wet grip then getting the longest lasting tire becomes a conflict. I am currently running yoko' avid ascend and they last crazy long (800 treadwear) stick well when warm and roads are dry, but put some rain in there and they become down right scary.
Just something to think about, don't put all your eggs in the treadwear basket or you'll have disappointing wet traction
Finding a good mid ground in my price range is tricky if not impossible.
I need to get tires asap thats the problem aswell as budget.
I got some good suggestions to work with though.
Thanks for the info.
Pinchlite is offline   Reply With Quote
Old 04-05-2017, 11:38 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
A 205/50 is tall and will throw your speedo off
I run a 195/50 on 1.8" MI springs with no problems same wheel dimensions
My 225/45-15 hoosiers on 7" 36offsets rub out back on the 1/4panel under hard cornering...do not know if thats the same for hatchies
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-06-2017, 05:50 AM   #3
Pinchlite
rub
You had 36 offset vs my 40 with more drop then mine.(1.5)
Also not buying new rims.I have what I have and sticking with.
Old 04-06-2017, 10:25 AM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
With stock 185/60/15's my speedo was not accurate out of the box. I run 205/50/16's... and my speedo is dead on!
Old 04-06-2017, 12:20 AM   #5
Just get the General Tire Altimax RT43. If you look up the reviews on them, many people got them up and past 70k miles, and it's rated very good for dry and wet conditions, and good snow conditions.
https://www.tirerack.com/tires/surve....jsp?type=GTAS
Those are the tires I'll be getting, but I'll be getting 195/50/60.
Old 04-06-2017, 01:31 AM   #6
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Those are some tall wheels you have. How's the speedo accuracy?
And Pinchlite don't leave the forum. There are so few of us Yaris guys as it is. Stick around!
Old 04-06-2017, 02:28 AM   #7
*in my best Estelle from "Friends" voice* Whoopsie.
lol. Meant 195/50/16.
Old 04-06-2017, 05:41 AM   #8
Pinchlite
speedo
Thanks and will stick around but wil do more research before quickly posting here for help.
Not too worried about speedo as I have a good feel as to what speed I
am going.I also go with the flow and drive slowly,safely,responsibly in town and school zones.I think it comes down to common sense and knowing what speed is appropriate for what environment and climate.Never had a speed ticket yet.
I may use a gps app to get an idea what my speedo is reading compared to real world.Should give me a good ball park.
Old 04-06-2017, 05:57 AM   #9
Pinchlite
general tire
Cant get this locally in my size.
They have these at canadian tire in most every size except what I need.
Its not even actually listed as a size general makes in this name(Altimax RT43).205/50/R16.
Maybe in the US only.
Old 04-06-2017, 08:25 AM   #10
Not available you say...
http://www.canadiantire.ca/en/pdp/ge...83191.html#srp
Also, the speedo will change by ~3% from what yours currently indicates so nothing earth shattering, just different.
Old 04-06-2017, 08:49 AM   #11
Pinchlite
I decided on these and just picked up this morning.Last 4 in stock.
http://www.canadiantire.ca/en/pdp/mi...p.0062221.html.
I did quite a bit of research on these and they dont seem half bad..Also $110.00.
I have appointment today@ Kaltire for swap,balance and alignment if needed.
Old 04-06-2017, 10:27 AM   #12
kimona
kimona's Avatar
Michelin Pilots? Now, that was a real find at that price. Way to go, man!
Post some pics after the install.
Old 04-06-2017, 11:32 AM   #13
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Ha, in the time it took me to get back to this thread and catch-up, you found and bought the exact same tires I'm running on my car. I can tell you they are super quiet and perform like a mf. I'm team Michelin Sport all day. Top shelf tires.
On Instagram
On Wheelwell
Old 04-06-2017, 03:43 PM   #14
Pinchlite
Just got back from getting installed and we had real heavy rain on the wayback.
These were beautiful in the rain aswell as quiet.
They cornered quite well and has smoother ride over bumps.
Totally happy with this tire..plus it eliminated some more gap.
I think its a really good tire and got on sale for $111.00 CAD.
Old 04-06-2017, 07:00 PM   #15
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
Old 04-06-2017, 09:32 PM   #16
Pinchlite
Michelins
Went out for a drive tonight and these are quite impressive tires.I think 50 is the sweet spot and am glad I run 205 R16 with wide tires.I like the heavier feeling of the steering yet very responsive.
This tire is being discontinued BTW.Not sure why ..maybe just in Canada?
Like I said earlier a couple of guys really liked the look of the car.
Another fella said why do up a yaris and I said its an extremly fun car to drive especially after lowering and putting on some decent/wheels/tires.
I have probaly seen 40/50?? or so yaris's in my area but have yet to see one modified period.
Hondas on the other hand are all over the place modified and arent even worth a second glance anymore....yaaaawn.
Another thing I notice is that every yaris I have seen,even 2007 models in these canadian winters have zero rust.1 hour north of Toronto here and lotsa salt and long winters.
The 2007/2008 hatch is my favourite yaris btw.
If I could afford it I would buy another and do it up for a purely summer only souped up version.
My only peeves are no intermittent rear wiper and it could of had indipendant rear susp,but that would have brought the cost up quite a bit(the rear susp part)
Oh..and a scirocco type yellow would have been a nice option.
Old 04-06-2017, 11:03 PM   #17
kimona
kimona's Avatar
Have to agree with you.
Glad you're enjoying the new rubber. I love 205/50/16's on this car.
Old 04-07-2017, 12:28 PM   #18
ern-diz
ern-diz's Avatar
...This tire is being discontinued BTW.Not sure why ..maybe just in Canada?...
Possible, but I know Michelin has the newer Premier line and A/S 4's, so I can understand these going away. Either way, their performance lines are top shelf all-season tires.
On Instagram
On Wheelwell
Updated forum rules ChinoCharles Suggestions - Feedback - Questions 5 12-15-2006 04:41 PM
new racing forum kngrsll Suggestions - Feedback - Questions 6 11-23-2006 05:06 AM
New to the forum spookme General Yaris / Vitz Discussion 14 04-25-2006 08:49 PM
