Old 06-20-2017, 08:07 PM   #1
Yaris709
Drives: 07 yaris
Originally Posted by NJP440 View Post
Ok time for me to jack this thread. I ordered an intake for my 2010 yaris 3dr and the air sensor does not bolt up at all! Very far off on the bolt holes. Yes I bought a cheap intake but for those who are on the facebook page and remember Aimee and her 3rd gen "laboon" she had the same problem with her AFE intake. Now we are talking $50 intake vs a $300 intake so I can't call quality here, there must be something else at play. Anyone run into this issue? Does our car have 2 different model air sensors?
Pic of my cheap intake for hilarity purposes
Sent from my LG-H918 using Tapatalk
I have the exact same issue with an intake I ordered. It sucks haha and I can't return it now cause I had it forgot about. Have to find a way to rig it up to work somehow. I could file out the maf sensor hole and try to find a way to secure the sensor down tight. The maf sensor is literally less than a mm to big but screw holes are off quote a bit.
Yaris709 is offline   Reply With Quote
Old 06-15-2017, 11:20 PM   #2
SirDigby
Drives: 2007 yaris 3 door
your options are; cut up stock box and aftermarket tubing and use 3 couplers and filter. buy another intake. use aftermarket tubing with stock air box. use stock tubing and stock air box.
Old 06-15-2017, 11:21 PM   #3
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
So no matter what you're 50/50 odds with ordering an intake?
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 06-16-2017, 10:25 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^^ok just making sure. That really sucks though.
Old 06-26-2017, 09:06 PM   #5
Yaris709
Drives: 07 yaris
Bump if anyone could point me in the right direction to get my intake to work
Old 06-27-2017, 08:22 AM   #6
heeroyuy01195
Post count means nothing.
If the screw holes are that far off it might be better to drill new holes and tap them if there's enough material. If not then I would say try and find a different intake or at least a section with a MAF mount. I think someone had one posted in the classifieds section on the forum. Can you put up a picture or two of the hole alignment?
Old 06-27-2017, 09:35 AM   #7
Bluevitz-rs
Does the sensor fit in the hole? The screws aren't esencial, they're just there to locate its orientation and keep it in place.
Old 06-27-2017, 09:43 AM   #8
NJP440
2010EGGHATCH
NJP440's Avatar
Sensor is maybe 1mm bigger than the hole
IG: 2010EGGHATCH
Old 06-27-2017, 09:58 AM   #9
Bluevitz-rs
Well if you have tools to make the hole bigger and get the sensor in there you can just seal it with a little silicone and zip ties.
Old 06-27-2017, 10:03 AM   #10
NJP440
2010EGGHATCH
NJP440's Avatar
That works
Ill post updates
IG: 2010EGGHATCH
Old 06-27-2017, 11:08 AM   #11
Bluevitz-rs
Just make sure it's oriented in the right direction and dead nuts straight.
Old 06-27-2017, 11:09 AM   #12
NJP440
2010EGGHATCH
NJP440's Avatar
I think I can bolt one bolt in? I don't remember honestly. When I saw it didn't work I ripped out the intake pipe and chucked it across the drive lmao. I'm off this weekend ill try it then
IG: 2010EGGHATCH
Old 06-27-2017, 06:52 PM   #13
Yaris709
Drives: 07 yaris
Never thought about zip tying the sensor down. That'll work! I'm guessing if I take a metal file to the hole ill be able to get it to fit. It's not off by much but enough to piss me off hahaha
Old 06-27-2017, 06:55 PM   #14
NJP440
2010EGGHATCH
NJP440's Avatar
Does one bolt hole line up? I can't remember at all I was in rage lol
IG: 2010EGGHATCH
Old 06-27-2017, 10:49 PM   #15
Yaris709
Drives: 07 yaris
Nope neither lined up on mine. Both were off about 3-5 mm or so. The maf is less than a mm from fitting but it wouldn't go down. I'd say I'll be installing it this weekend coming & I'll let you know how it works out
Old 06-27-2017, 11:01 PM   #16
NJP440
2010EGGHATCH
NJP440's Avatar
Ill be doing the same haha ill get crafty with some zip ties
IG: 2010EGGHATCH
Old 07-01-2017, 07:31 PM   #17
NJP440
2010EGGHATCH
NJP440's Avatar
Well I did it. Bore the MAF hole out 1mm shoved the MAF in and ziptied it on snug. Intake is on
IG: 2010EGGHATCH
Old 07-01-2017, 08:39 PM   #18
heeroyuy01195
I would be a little weary of the zip ties on the MAF, don't want any leaks there. Maybe you can make an adapter with some aluminum stock.
Simota CF650-6 Air Intake Review invader166 Performance Modifications 16 12-21-2015 04:31 PM
For Sale: Fujita F5 Cold Air Intake invader166 Items for Sale by private party 2 11-21-2015 12:10 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 09:11 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 03:03 PM
cold air intake 400 dollar yaris Performance Modifications 10 10-02-2012 07:33 PM
