Old 04-11-2017, 02:01 AM   #1
alias06
Drives: 2008 Red Toyota Yaris
Originally Posted by bgolash View Post
Hi, A battery is DC so wouldn`t the amps be considered DC. I`m not trying to second -guess you. Just trying to understand the theory.
I did move the probe to Amps and set the meter to 20 amps. Then took the reading. If I`m recalling correctly what I did.
For the hell of it, I`ll follow the video a second time and check myself.
Thanks for the reply!
When you are reading Voltage (V) on a battery it is in DC voltage. Current is measured in Amps (A). If you are going to follow the video in the link from the previous post make sure that you do have the battery disconnected with one lead going to the negative post while the other lead has a good connection with the grounding cable. Don't forget to make sure that the meter is in the correct configuration for the test.
alias06 is offline   Reply With Quote
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Yaris 2008 does not start sberdina DIY / Maintenance / Service 8 04-06-2010 02:03 PM
Not sure where to start (2009 yaris)... Faith87 General Yaris / Vitz Discussion 37 03-23-2009 05:35 PM
