#181 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
#182 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Installation was pretty straightforward. My advice would be to start with spring bolts (two bolts that connect hader to the midpipe) - I unbolted the header first thus had a little problem with spring bolts later. Bolts other than spring bolts were easy to remove. No issues whatsover with removing the o2 sensor as well.
Fitment: the header fits perfectly (had minor issue with big bolt that fastens the lower part of the beader to the engine - kinda support the header/midpipe coupling). Driving impressions: no torque loss in the low/mid range.. feels like some gain overall. The car easily hits 100kmh in the second gear (6700 rpm)- not sure it was feasible before. Could not be happier. Some pics will follow. |
#183 |
some pics
all top crap removed to access the header http://photo.qip.ru/users/tolmach/96608749/129640535/ all crap moved to the trunk while working on the header http://photo.qip.ru/users/tolmach/96608749/129640844/ stock header, heat shiled removed http://photo.qip.ru/users/tolmach/96608749/129640829/ stock header removed, gasket (to be reused) http://photo.qip.ru/users/tolmach/96608749/129640832/ traditional pic http://photo.qip.ru/users/tolmach/96608749/129640833/ http://photo.qip.ru/users/tolmach/96608749/129640834/ inside pic http://photo.qip.ru/users/tolmach/96608749/129640837/ new header in place http://photo.qip.ru/users/tolmach/96608749/129640843/ |
#184 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
#185 |
^ Thanks.. Sure I can (PM-ed)
#186 |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
I know this header is ceramic so there's no need to wrap it right?
#187 |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
DO NOT WRAP A HEADER!!! wrap is bad avoid it, it holds moisture and increases corrosion. Its coated leave it as is.
#188 |
Thank You for the advice
#189 |
#190 |
![]() Drives: 07' Yaris Sedan Join Date: Aug 2013
Hey, question about installation. It is possible without jacking up the car? People say they think you can, but can I? Want to install it today, but have no jack stands, unfortunately.
Blake |
#191 |
Possible? Sure.
PITA? Definitely.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#192 |
Hm, I guess i'll just go for it. I'll have a person to help me, hopefully works out.
#193 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
The flange bolts from header to downpipe are only accessible from below. I don't know about you, but personally I cannot fit under the car if not raised.
#194 |
I'm thinking to drive the front of the car on a curb just enough, so it would be sitting over the concrete, on the grass. Then I can slide underneath and hopefully reach the bolts still. Or is there a reason why this is flawed ?
Won't be on grass, just concrete. Going to do tomorrow morning. |
#195 | |
play every day
If you can, post some pics of your installation. Greg |
#196 |
![]() Drives: 2011 Yaris 3dr Join Date: May 2013
Is there a reason you don't put the heat shield back on? You'd think you'd want to, to keep your engine bay cool and exhaust header hot.
#197 |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
I just installed mine yesterday and i LOVE it. it was a PITA to take out the stock header without a 12mm deep socket.. so if you are thinking of getting the dc header make sure to get one! I ended up going to the store to pick one up when i got to the last bolt.. lol. No CELs and no leaks! Definitely recommend it.
I have an afe short ram, trd axleback, MI pulley and I'm an AT. I definitely feel a difference and getting to 60-70mph is like butter.
lol okay |
#198 |
![]() Drives: Yaris RS2 2012 Join Date: Oct 2016
TRD made a 4-1 header (exhaust manifold) for the Vitz 1NZ-FE.
