Old 04-24-2017, 05:36 PM   #1
tmontague
tmontague's Avatar
Average mileage for OEM wheel bearings
Obviously this will greatly vary since we all drive in different climates with varying road condition. I'm curious as to what mileage many of you guys have gotten out of your oem wheel bearing?
2 days ago I just started noticing a vibration under very hard cornering only from the rear left wheel. No other symptoms or noises and no signs of rubbing ox tires issues. It feel like the rear left tire is flat and I'm riding on the edge of the rim over a bumpy surface. I can make this happen in corners by swinging the rear out (understeer and then oversteer). No noises are heard though, just the strong vibration.
I'm at 182k km now so not too shabby by any means if I do need new bearings. Especially since the conditions I drive in and how bad the roads are in Hamilton Ont.
I'm thinking of going with a MOOG replacement assembly on RockAuto ($179 CAD) comes with a 3 years warranty. Beats paying $240+13% tax from my local Parts Source for it.
Old 04-24-2017, 06:51 PM   #2
Rigaud
Drives: 2009 Yaris
2009 2 door hatchback, 120,000km it started and this car rarely came out winters. Yaris are known for bearings wearing out at lower km's.
My girlfriends Mazda 3 has 251,000 and one side needs replacing.
My 1998 Subaru LGT has 290,000km and still OEM not ever replaced.
My 2002 Audi |A4 Avant same thing at 291,000km original bearings.
Old 04-24-2017, 06:57 PM   #3
2006 HB with 302,000 km and original bearings still good.
Old 04-24-2017, 07:11 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
'05 one driver's side bearing at 175000
Old 04-24-2017, 09:20 PM   #5
tmontague
tmontague's Avatar
Thanks for the in put guys. Seems I could be due for a wheel bearing to go and it isn't out of the norm for the Yaris.
I quickly raised my rear when I got home from an exam and the left wheel has zero sign of play or any issues/binding when turning. The wheels also were properly torqued. I guess it's still possibly a wheel bearing as some can be almost asymptomatic and still be on their way out, but nothing yet other than the original issue is showing any signs. Still zero signs of any type of rubbing or damage to anything. I pulled on the shocks and nothing was loose or making any noises.
I'll pull both rear wheels tomorrow and I'll check the left hub with the wheel and drum off and see how it spins. Also I'm going to check the hub bolt torque.
Let me know if you guys have any other ideas.
Old 04-24-2017, 09:36 PM   #6
vwhugger
Drives: 2008 and 2012 Yaris 2dr
My 2008 Yaris has 294,000 miles on it and I've never replaced the wheel bearings or for that matter, any other thing in the drivetrain. Same with my my 2012, which has 180,000 miles on it. Just normal stuff like spark plugs, brakes and serpentine belts have been replaced.
vwhugger is offline   Reply With Quote
Old 04-24-2017, 09:43 PM   #7
SirDigby
Drives: 2007 yaris 3 door
in my experience, Timken are the best! idk if they make a hub assembly though. i'll have to see what i can find...
Old 04-24-2017, 09:53 PM   #8
SirDigby
oooooooo they do! that's what i'd get...
Old 04-24-2017, 09:57 PM   #9
SirDigby
carparts.com has them for 42.35 usd. for ABS. non-abs even cheaper...
Old 04-24-2017, 10:00 PM   #10
tmontague
tmontague's Avatar
Don't you have to be a mechanic to buy from carparts?
Old 04-25-2017, 09:32 PM   #11
SirDigby
nah. it's an online store. idk about Canadian shipping...
Old 04-25-2017, 09:39 PM   #12
tmontague
tmontague's Avatar
it's no worries, I have a US PO box. I got it mixed up with car-part.com
I ended up finding MOOG bearings off of Ebay from a Texas seller for about $100 USD each which is a great price. Beat RockAuto by quite a bit
Old 04-25-2017, 09:42 PM   #13
tmontague
tmontague's Avatar
Update:
I removed the wheels this evening and spun the bearings and there didn't seem to be any issues with them. They didn't spin freely but that's expected in a car with 182k km on it. I then removed the hub (took 30 mins and had to McGyver a hub puller to un seize them) once I had the hubs in my hand and spun them I could feel some crunchiness to the left one especially and even aslightly to the right one.
I swapped them on opposite sides and went driving. I still have the same vibration in the left under hard cornering but it seems slightly better. This makes sense considering both hubs are on their way out but the left one was worse
I'll update this once I get around to installing new hubs, hopefully the vibration will be gone.
Old 04-26-2017, 09:46 PM   #14
SirDigby
i thought they were bolt in. why the puller? is it just from corrosion?
Old 04-27-2017, 12:19 AM   #15
tmontague
tmontague's Avatar
The hub was seized to the dust shield so bad and there isn't a way to really leverage it out or even use an air hammer. If only the factory used anti seize...
The dust shield/hub fell off the axle when I removed the bolts since I have anti seized it when installed my Penguin axle spacers last summer, but I never removed the hub from the dust shield then as it was seized.
There is a great video on YouTube of a guy showing you how to make your own puller for cheap with some bolts and washers. He used it to do his rear hub on his toyota minivan.
Old 04-27-2017, 09:20 AM   #16
zoidberg444
zoidberg444's Avatar
130,000 miles on my shitbox so far and still on all original wheel bearings. Hopefully i haven't jinxed it.
UK to Nordkapp in a Yaris
Old 04-28-2017, 12:25 PM   #17
mimelio
Drives: NONE
What ever you do DO NOT UNDER CIRCUMSTANCES GET A BRAND OF BEARING CALLED DETROIT AXLE...You will see them super cheap and they only last about a year. I had a passenger rear start making noise at 60,000 and I replaced it with an Genuine Toyota Bearing
mimelio is offline   Reply With Quote
Old 04-28-2017, 01:49 PM   #18
zoidberg444
I thought the OEM bearings were made by Koyo were pretty much the best available as far as bearings go for automotive use?
Maybe its the salt and grit on the roads in the northern hemisphere that kill them early?
Sent from my SM-G900F using Tapatalk
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 02:37 PM
2007 3 door 350000 miles eats wheel bearings! webfeet69 General Yaris / Vitz Discussion 23 12-15-2009 08:20 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
