Old 05-02-2017, 04:57 PM   #1
Originally Posted by m.flores.0928 View Post
To that end, should I look at rolling my rear fenders too? I hear that's something I can do to minimize rub also.
That is wholly dependent on wheel offset and tire width. If light rubbing does occur with your particular wheel/tire setup, adding a small amount of camber is the easiest and least destructive way of eliminating it. Extreme rub will require fender rolling.
Springs? I'm not going there. So many spring threads on this forum. Lots of info to be had since second and third gen are the same.
Old 05-02-2017, 04:59 PM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Adding camber to the rear suspension is pretty limited though, right? It's not an adjustable suspension beyond those flimsy hub shims. Also, I would rather have light rub over visible differences in camber.
Is rolling the fenders an intense job?
m.flores.0928 is offline   Reply With Quote
Old 05-02-2017, 05:07 PM   #3
KenTK808
Drives: 2014 Yaris LE
I'm running Tein S-tech lowering springs that are for the Scion XD on my 2014 Yaris. I chose these because they are progressive and the rates for the rear are higher on the Scion XD springs, not by much but it would make a difference if you're packing people in the back.
If rubbing is an issue you could run a smaller series tire or go to a reputable shop that would roll the edges of the fenders. Shops around my area use fender rolling tools and a heat gun to not crack the paint. Make sure you take it to a shop that knows how to do it right and wont bacon the shit out of the fender.
KenTK808 is offline   Reply With Quote
Old 05-02-2017, 05:09 PM   #4
m.flores.0928
Drives: 2014 Yaris
Aha so they do work! Awesome. I'll look into those.
I prefer this size tire, I had to special order them from the tire shop I went to, I want to work around the tires I have now. I'll hunt around for a body shop around here.
lowering, springs, tire rub
Lowering springs for 2013 Yaris? manualmotive Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-15-2016 06:26 PM
AG Lowering Springs + XA Raceland Rear Springs! So-Cal!! braytonia Items for Sale by private party 6 09-21-2014 10:30 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
