Old 05-06-2017, 02:35 PM   #1
bronsin
bronsin's Avatar
You are being had ie lied to.
Difference in compression between two cylinders has nothing to do with oil consumption.
Start checking your oil once a week. Add oil to bring the level up to the top line. Its OK for the level to be somewhere between the two lines but when it gets near the bottom one, add half a quart and check it the next day.
Check the oil in the morning with a cold engine that hasnt been run overnight.
Then report back.
PS My wifes car with 140,000 miles uses a quart of oil every 4000 miles.
Old 05-06-2017, 02:51 PM   #2
rtk
Drives: Yaris 2010
Then report back.
Yes, the garage told me to check as well. What are possible negative effects of the difference in valve pressure? Lower engine power?
Thanks for the help!
rtk is offline   Reply With Quote
Old 05-06-2017, 03:52 PM   #3
Goosecreekjoey
Drives: 2008 yaris
Oil consumption
Hey you would lose a little power. That's less compression, means less power. That amount in one cylinder I don't think you would feel it. Unless you guys are drag racing. My 2008 HB 135,000 miles never uses oil, freaks me out. Highway miles like driving 75-80 for long period of time will use oil and of course aggressive driving will do the trick also. Would really be surprised if there is and internal problem that motor is TOUGH.
Goosecreekjoey is offline   Reply With Quote
my first DIY oil change since 1988 justanotherdrunk DIY / Maintenance / Service 15 03-01-2017 10:58 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Used Oil Analysis : 2010 3 door Yaris : 4,341 mis. on oil and 16,611 miles on engine Hershey DIY / Maintenance / Service 22 08-04-2011 10:52 AM
Engine oil ?! I'm really confused BLOODY_STONE DIY / Maintenance / Service 31 06-09-2011 06:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
