Old 05-21-2017, 10:31 AM   #1
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
The next piece to go with bass is the bigger black plastic one to the rear of the door. Both of mine blew off on the freeway. Had to get new ones and glue them in place. Check them see if they are starting to separate before you loose them.
Big bass will eventualy work these loose, then the sun visors next. I ran 2 kicker isobaric L7-15" in the trunk it took about 3 months to blow them both off and rattle my brain. To much bass, to much weight. They sit in my living room now until I can figure out a more reasonable set up.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Old 05-21-2017, 11:39 AM   #2
Pinchlite
Drives: 2007 yaris HB
The issue was that the 2 plastic pillars on the back side plate broke off.
There is a clip that slide into place and that is okay.
I cut thin strips of 3M outdoor tape and lined the backside of outer edge of plate and reinstalled.Seems to be on real good and tape is not visable at all.
I will take a look at the other plates you are talking about.I dont have a big system just a 10'' infinity/ported with R500X1D.Nice tight punch but doesnt rattle the car.
This plate is not mounted firmly factory but kind of loose.I thought the noise was comming from under dash,or the dash itself and know is all good.
Pic of setup.http://i.imgur.com/6oQpuWf.jpg
Are you referring to the pillar covers between rear quarter window and drivers/passenger door?...those came loose aswell?
Pinchlite is offline   Reply With Quote
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Thailand OEM/Aftermarket Accessories and Bodykits GB Round 2! eTiMaGo Items for Sale by private party 118 09-10-2007 02:10 PM
Round filler piece on front bumper??? jdubau55 Cosmetic Modifications (Exterior/Interior) 4 04-13-2007 09:24 PM
Removing front bumper fat45s DIY / Maintenance / Service 1 01-31-2007 06:25 AM
removing front plate Lowfront Cosmetic Modifications (Exterior/Interior) 19 08-25-2006 09:59 PM
