Mechanic says I need a new blend door actuator
My AC was not working it was blowing hot so I took it to Pep Boys with a free AC check coupon
They checked and said I need a new blend door actuator. I think it is behind the glove box and from the youtube videos it is very easy to change it. But it is very expensive, I can not find it less than $30. Does it make sense to buy used? Also has anyone changed this before? What should I be looking for? |
#2 | |
Never heard of this issue before on this forum so don't know what you are up against or even if the diagnosis is correct. Sent from my Elite_5_5_Octa using Tapatalk
I don't know what year yaris you have but afaik they all had mechanical actuators via a cable.
And even if your blend door was stuck on recirc or fresh it would still blow cold if your ac worked fine. Your issue is likely something else. Either that, or young age a newer yaris with very different ac parts that I'm not familiar with
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
I hope your power lock actuator never fails. You might pass out!
This is 2009 Toyota yaris. Pep boys told me it is blend door actuator and they also said one part of the car blows cold the other part hot air because of this actuator
Ok, so it's not the air recirc actuator but the temperature control actuator. I'm surprised an '09 yaris would have an electronically controlled actuator.
Either way the part is cheap and shouldn't be too hard to replace if you pull the glove box. The smaller your hand the easier it will be lol.
| good mechanic (central FL) | yaris9876 | Southeast | 12 | 01-31-2014 09:41 AM |
| A day out with mechanic went wrong- Right arm problem | talhahs | DIY / Maintenance / Service | 6 | 05-17-2013 05:20 PM |
| Toyota Dealership Mechanic Scratched one Rim | YodaBird | Third Gen Yaris General Discussion | 20 | 05-17-2013 04:03 PM |
| Good mechanic in Barrie Ontario | the other hand | Canada | 0 | 08-08-2011 09:49 PM |
| GOOD Mechanic needed! | bkndacn | General Yaris / Vitz Discussion | 2 | 07-27-2010 07:51 PM |
