Old 05-25-2017, 01:40 PM   #1
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
I have done one. There was a lot of beating and I ended up damaging the bearing and buying a second one. So in the end I saved $70 and it took me 3 hrs. With a the proper equipment (a press) it's an easy job. Without your beating the hell out of the hub and spindle and likely a finger! $140 is a good deal. Save your self the time and finger!
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Old 05-25-2017, 07:04 PM   #2
Pinchlite
Drives: 2007 yaris HB
bearing
Will do and thanks.
He said 1 hour approx and I will be good to go.Getting it done sat morning.
This mechanic has worked on the car since it was new(after warranty)
I bought this yaris from my sister so i know its history and this mechanic seems like a really decent fella.
Pinchlite is offline   Reply With Quote
ac compressor bearing replacement. futuredenied DIY / Maintenance / Service 5 09-12-2025 01:04 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
