![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
That's the one I have in my car, except it's running off the pre-amp sub output of my aftermarket HU, but you could achieve the same using the speaker line level input. It won't drain any power from your head unit, it will only read the speaker signal and use its own power source to move the sub (you have to run 8ga copper wire on a 20a fuse from the battery to the sub).
If you look at other similar sub, you'll see that some of them also feature a second channel built in amplifier that will allow you to power another set of speaker from the amplifier powering the sub. That's also a cheap alternative to installing a dedicated amp just for 2 speakers. |
#2 | |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
And what about the speaker that I have in this line? Can I keep it too? Well that's really interesting Sent from my iPhone using Tapatalk |
#3 | |
You simply wire the subwoofer amp input in parallel to any of the 4 speaker channel, usually you can input a left and right line, so 2 channel (2 pairs, 4 wires) and that replace a pair of RCA cable. |
#4 | |
Or else I will need something like this ? https://www.amazon.com/gp/aw/d/B001E...7ESYQM60R1KP4Y Sent from my iPhone using Tapatalk |
#5 | |
Aftermarket Stereo / Speaker Specifications
Yes. |
| aftermarket stereo kit? | xCookiE | General Yaris / Vitz Discussion | 4 | 02-16-2006 10:33 PM |
